89 Pace Car
Old 03-03-2010, 06:01 PM
WS64Mula's Avatar
Default 89 Pace Car
Does anyone know if the Grand National front coil springs are the same as on the 89 Pace Car since the motor weighs 100-120lbs less or did they just use the V8 springs? Thanks.
Old 03-03-2010, 06:38 PM
TTA850's Avatar
I dont think they are the same, the Trans Am has the WS6 suspension package which should be much stiffer than the Grand National. The 1989 Turbo Trans Am used a front spring that carried the BXX code, part number 14029396.
HTH,
Steve
Old 03-06-2010, 08:28 PM
WS64Mula's Avatar
Problem is I need to figure out what springs I can use. The car currently has lowering springs that don't give the car much suspension travel. Eibach's I think. So, what springs can be used? I was looking at the global west set that drop it an inch, but doesn't hurt the ride or weight transfer.
Quick Reply: 89 Pace Car
