AFR at WOT in the 3k area??
13 Second Truck Club
At what AFR do you guys usually notice the best power around the 2k to 4k rpm with a cam? Its a big deal to me cuz i dont have a stall. My mods are in my sig. Thanks!
It depends on where you set MAP & throttle change percentage to differentiate WOT fueling from normal driving fueling. Regardless, best power would be in the 12.8-13.0 AFR range. If you tip in @ 2K it'll start @ stoich & then drop to 12.8 or so as the RPM's increase.
