another question for todd2001 or anyone with the helms manual or whatever...
does the book show how to remove the stock camaro ls1 grill the RIGHT WAY? I don't want to just PULL IT OFF I would like to remove it properly. So maybe if you could scan a page that has that description it would be great! Thanks.
Re: another question for todd2001 or anyone with the helms manual or whatever...
TTT
the only way to remove the grill other than yank it off (what I did) is to get inside the bumper to do it.. that would involve removing the 8-10 bolts from the bottom along with the 3 push pins on the bottom-middle of the bumber.. you should then be able to move the bumber enough to reach the clips..
Good luck.. anyone else with better advice?
