Passing OBD II with EGR, AIR, and rear O2 sensor tuned out
After the 3 are tuned out (no SES light) and I bring my car to my emissions center will these sensors read ready so I can pass the emissions test?
As long as the codes are set to SES Enabled and No Error Reported you should be fine. That's how mine are set and it passes. Here are a few links I dug up on the subject.
https://ls1tech.com/forums/pcm-diagn...readiness.html
https://ls1tech.com/forums/pcm-diagn...test-help.html
Good luck,
Larry
Good luck,
Larry
Good luck,
Larry
Good luck,
Larry
Thank you sir
