Please help, Elec. Issue
Now Im dumbfounded. I tried to crank it this mourning and it cranked right up. Turned it off tried again and dead!!! Then I went back out there about an hour ago and she cranked right up. Let it run for a while killedit then tried it again and NO go!!! Later this afternoon this is what I found. I dont understand. Any ideas?
Shows 12.2 volts sitting
Shows 10.5+ volts cranking
Cranked up 3 times in a row in succession.
How does a battery charge while sitting?
Trey
Trey
do you have headers &/or gm starter? if the motor was hot when you shut down then it sounds kinda like a weak starter due to "heat soak" you will prob. have issues till you swap out if that is the case
