Using 83#injectors HPtuners only goes to 63....
Is there any way around this? I purchased 83#injectors for my car but when I go to enter them into the slots they automatically go to 63#s.
Im not using a MAF. I applied the 2bar OS. Im having it tuned in open loop completely. Some are saying just simply add say 30% to the ifr vs. volts and that would make the 63.5s 82.5s....
If you got a LS1 ECU with harness and a extension adapter for your front mount cam sensor you are good to go. The only other thing is if you are using knock sensors, you have to use LS1 knock sensors. At the point you are at though, it may be easier to manipulate the ECU instead of starting over with the wiring.
I think id have to take away not add....if the injector is bigger and the ecu thinks its a smaller injector it would open and close it the same as a smaller injector but with it being bigger it would dump more fuel...I could be wrong though...
Basically... take the [max injector value] / [your new injector size] and then multiply the entire VE by the resulting number (will be less than 1 as you noted).
HOWEVER, in your timing tables now, the same % will need to be applied to cylinder fill. What was 1.0g/cyl will now be the number derived above * cyl air mass. You will have to go back through your main and idle timing tables and any modifying tables as well.
