What Alternator Should I Buy For Replacing My OEM Alternator?
Last year I was having problems with all my lights flickering and dancing. You can read more in this thread; https://ls1tech.com/forums/stereo-el...me-inside.html
So I think I have come to the conclusion that my alt. is going bad. What should I replace it with?
Right now my radio is all STOCK.. and I have a Red Top Optima..
Thanks
Thanks
Well, you can take your chances with AZ or O'Reilly. If you do, just make sure they put it on the machine and prove that it works, first. I've seen lots of the folks here say you can't go wrong with a NEW Delco, though.
Best thing to do is seek out a specialty alternator/starter shop in your area, and have them rebuild it. I did that with my alternator, and they charged me 140 bucks for hop it up to a 140 AMP, with heavy duty everything on it.
They don't make new Delco units, the best you can do for that route is re- manufactured, which isn't really a step up from what else is out there.
I'm going on almost 2 years with my Pro-Start from PepBoys.
$149.00 Lifetime warranty, so I'll never pay for an alternator again.
1000 watt amp blasting with a 12" woofer, headlights on high beam, A/C blasting on high.....it doesn't skip a beat at all. No dimming problems at idle or under throttle, its perfect.
