blueZ28beast
03-06-2010, 05:53 AM
I have a 1998 NBM Z28. It has around 79,500 miles. It ran a 7.82(1/8th mile) @ 93mph I believe. Of course that was three years ago. That was with a stock tune. If the car had a performance tune I am guessing it would run more around the 7.50 range.There are several small things wrong with the car. Just little stupid things that I have never had a chance to fix because I am always gone with the Army. The first: the paint around the nose is starting to chip. I suppose it is normal wear and tear for a car that sits that low to the ground and is 12 years old. Next is the drivers side window. As you probably know camaro electric windows are a huge pain in the ass. Supposedly there is a clamp that holds the window in place that is broken. So the window slides around. The motor works but sometimes if the window isn't in the right position it will not come up. The last thing a crack in the clearcoat on the bumper. My father accidentily gave it too much gas one day and it broke loose and he went through a ditch with it. He told me he would get it fixed but I told him not to worry about it because I don't really even notice it.
TEA Stage 2.5 5.3 Heads
Comp Cam 224/224
Hooker Super Comp Headers(ceramic coated)
Mufflex 4" y-pipe
Spintech 4"exhaust
RPM Level V A4
Yank 3000 Stall
LS6 intake
Comp Hardened Pushrods
Ported TB
ASP pulley
28.8 Injectors
SS rims
3.42 gear
New A/C compressor
New O2 sensors, spark plugs, and wires
Car is located in Lewisburg(37091),TN. It is an hour south of Nashville.
$8,500 OBO
Comp Cam 224/224
Mufflex 4" y-pipe
Spintech 4"exhaust
RPM Level V A4
Yank 3000 Stall
LS6 intake
Ported TB
ASP pulley
28.8 Injectors
SS rims
3.42 gear
New A/C compressor
$8,500 OBO
