Need to raise the car up a little bit
I have a 2000 SS with the Pro kit, after the install of my MWC 9 inch, the car seems to bottom out really bad even on the the smallest of bumps. I was wondering if there was a alternative to buying new springs for the rear, just want BANG BANG BANG to stop. The rear islators are still in the car.
Any ideas. Maybe a spacer between the bottom of the spring and rear end? Or stop being a cheap *** buy some strano rear springs. LOL
what shocks do you have? if you're still on the stock shocks, i'd consider upgrading, it just may take care of the issue.
as for raising the rear, you can either get different springs, or you can add a spacer between the rear & the bottom of the spring....either way should work just fine.
