help with brakes!!!
Old 03-07-2010, 05:47 PM
jman0322's Avatar
Default help with brakes!!!
I just changed my rotors on my 04 GTO and now its locking up when I try to go forward but fine in reverse, what did I do wrong???
Old 03-08-2010, 07:39 AM
Save the manuals!
wssix99's Avatar
Did you replace the rear rotors? If so, did you adjust your parking brakes to the new bore of the rotor hat?
Old 03-08-2010, 08:35 AM
jman0322's Avatar
I did and adjusted the one on the driver's rear because it was difficult to get the new one on and I think that is my issue but I'm not sure how to properly adjust the parking brake.
Old 03-08-2010, 11:15 AM
Save the manuals!
wssix99's Avatar
It sounds like they may still be too tight.
The procedure is in this thread: https://ls1tech.com/forums/suspensio...ightening.html
You measure the adjustment at the end of the lever on the back of the drum plate. (You can do this without taking the tire off:
- Be sure to block the wheels so the car doesn't move!
- Release the parking brake
- Manually pull the parking brake lever that the parking brake attaches to. A properly adjusted system should allow the lever to move 3mm. If its less, than the brake is too tight. If its more, than the brake isn't adjusted tight enough.
Old 03-08-2010, 12:22 PM
jman0322's Avatar
Thanks but I guess the only thing I'm still unsure about it is that to me when I'm looking at the adjustment wheel its either up or down not left/right or clockwise/counter clockwise??? Also if everything is right then I shouldn't have to fight to get the rotor back on right? Again thanks for your help!
Old 03-08-2010, 02:16 PM
Save the manuals!
wssix99's Avatar
Good point. If I recall correctly, the left or right corresponds to if the star wheel was a nut turning on a bolt. (Its been a while since I've been hands on with them.) In reality, you will either turn the wheel up or down. Either way, if you turn the wrong way, you'll be able to tell through the play in the lever.
Old 03-08-2010, 04:34 PM
jman0322's Avatar
Alright freed up the parking brake but now front right rotor sounds terrible but doesn't pull or anything. Do new drilled and slotted rotors sound rough at first?
Old 03-08-2010, 05:41 PM
jman0322's Avatar
Got it going my dumbass put one of the pads in backwards...never done that one before...LOL
Old 03-08-2010, 06:04 PM
Save the manuals!
wssix99's Avatar
Ouch!
Old 03-08-2010, 06:41 PM
jman0322's Avatar
Yeah can't believe I even admitted to it...lol
Old 03-09-2010, 12:22 AM
spy2520's Avatar
hilarious...
Old 03-09-2010, 03:14 AM
TireSm0ke's Avatar
LOL I almost pissed myself when I read this
Old 03-09-2010, 03:16 PM
Brakemotive's Avatar
If it's any consolation it happens more often than you'd think Glad you got it sorted out.
Old 03-09-2010, 07:37 PM
jman0322's Avatar
And thank you for the great deal on the rotors!!!
Quick Reply: help with brakes!!!
