Drag Racing Tech
slammed f-bodys with 325/50 or 28/10.5 no tubs
Old 03-07-2010, 07:58 PM
daniel6718's Avatar
Default slammed f-bodys with 325/50 or 28/10.5 no tubs
dont care about rear width or backspacing as long as your not tubbed whose done it and got pics?
how low did you get it without running into problems? i know im going to have to cut the trans tunnel but want to keep the stock plastics on the sail panels uncut...
Old 03-08-2010, 11:42 PM
daniel6718's Avatar
anyone
Old 03-09-2010, 02:06 AM
Wicked94Z's Avatar
see small sig pic... i don't know if you consider that slammed, but on level ground the tire sits slightly inside the wheelwell
Old 03-09-2010, 02:43 AM
camscam02's Avatar
This is what im shooting for. Not sure if it is tubbed or not, he is a member here, just havent had the time to ask him yet.
Old 03-09-2010, 10:54 AM
Mikey 97Z M6's Avatar
I'm getting a big red 'X' for that pic lol.... ?
I'd like to see some of these cars also, if it's even possible. I'm not mini-tubbed but I'm going with some 28x10.50-15 on 15x10" wheels and my car is lowered. Hoping I don't need to raise the car to fit the tires/wheels.
Mike
Old 03-09-2010, 11:31 AM
trigger1's Avatar
The car in my sig is on a 28x10.5 ET drag. Stock springs with isolators removed. I don't think I could go much lower without a tub.
Old 03-09-2010, 12:01 PM
tee-boy's Avatar
you running a 9"
Old 03-09-2010, 12:02 PM
trigger1's Avatar
tee-boy, I'm running a 9" narrowed 3" each side with a 15x10 5bs magnum.
Old 03-09-2010, 01:12 PM
camscam02's Avatar
That is weird the pic worked last night, and just edited it again so hopefully it stays.
Old 03-09-2010, 01:15 PM
Mine will be narrowed 3"/side also, except I'm gonna try a 4.5" bs. How close is your tire to the outer fender lip with yours?
Mike
Old 03-09-2010, 01:17 PM
Seems to be working now. That stance looks badass...
Mike
camscam02's Avatar
My car is decently low, we had stock springs, cut one full coil with no isolators and it was the perfect stance but with a 28x10.5 stiff it would have hit the fender lips when the tire grew and we didnt want to roll them, so we put the rear isolators back in and it still looks pretty good.
Old 03-09-2010, 01:24 PM
TS6
TS6's Avatar
The silver car above seems to have an F body offset type rim on it but it also looks like the frontside of the 1/4 panel was trimmed out some, like when guys run 29"-30" tires. It looks pure evil though!
It is easier to "tuck" a 28/10.5 than a 325, 325 is more like a 10.5W tire.
Old 03-09-2010, 01:35 PM
What backspace are you running on yours? Also going to be using the stiff sidewall slicks here. I'm not too concerned about rolling a fender lip if needed.
Mike
Old 03-09-2010, 01:40 PM
camscam02's Avatar
We use a stock length 9inch with what i'm guessing is 7.5" backspace Bogarts.
here is a vid of the current stance, dont have any pics. this is stock springs with one coil cut and stock isolators.
[IMG]9.92 Pass[/IMG]
Old 03-09-2010, 02:18 PM
gator's 99TA's Avatar
its funny that i am actually in the picture.
Old 03-09-2010, 02:22 PM
https://ls1tech.com/forums/drag-raci...owed-rear.html
Old 03-09-2010, 02:23 PM
https://ls1tech.com/forums/drag-raci...dial-pics.html
a search comes up with a ton of these pictures. to slam a 28x10.5S is easy as hell. a 325 is another world.
Old 03-09-2010, 07:48 PM
daniel6718's Avatar
yeah it did but i was tryin to do with witout tubs...i didnt se the 2 posted above the other night thanks///really wanted to go lower then those
Quick Reply: slammed f-bodys with 325/50 or 28/10.5 no tubs
