SES Light on
SES Light on
On my 06 impala it has 62XXX miles since ive owned it ive used premium gas and mobil 1 synthetic oil. I pulled the code with my scanner and its a p0302 cylinder 2 misfire. I changed the spark plugs,wires,coil pack. I erased the code,drove the car around it seemed fine, turned it off sat for a while turned it back on i drove around the block and it comes up again along with service traction control . What else can it be?, a bad injector??? Also when im coming to a complete stop i feel the car just a little shaky..
If its shaky when coming to a stop it might be time for new brake pads.
As for the codes...was it the same code as the first time? Did you delete it with an OBDII scanner or like a Hypertech Programmer or something similar to that? How long did you drive the car after you cleared the code?
It does come up as the same code and i clear it with an OBDII scanner i dont know exactly but i would say 15 miles or less, then i got home turned it off and i left it sitting for a while, turned it back on and the ses light came back, giving me the same code.
I c on how swaping the injector to the other bank would help me determine for a faulty injector. an o2 sensor as well could be to blame for ill look into prices in the dealer. Ive also been reading that it can be a clogged cat converter ?
Yeah I understand that. I wonder if i have to take the damn intake off i havent really seen where the injectors are located on that car. on our f-bodys theyre a simple thing to do but i dont know on this car.
