Clutch sounds like a turkey!
Old 03-08-2010, 11:09 AM
FUH Q's Avatar
Default Clutch sounds like a turkey!
I asked a while back and I was told that when the clutch is cold it is normal for a little noise for a few minutes. Now, though, it lasts longer, is louder, and happens in any weather. When moving from a stop in 1st gear, the clutch makes a loud turkey like noise untill I come mostly off the clutch. The car has a spec clutch that came with the car. Not sure of the miles on the clutch. Is this noise normal? Thanks.
Old 03-08-2010, 08:58 PM
FUH Q's Avatar
BUMP
Old 03-09-2010, 11:30 AM
FUH Q's Avatar
Bump...
Old 03-09-2010, 11:38 AM
pokaspeed's Avatar
My spec does this once in awhile. I just slip it for a second or two and it goes away. Do you have a ligjtweight flywheel? I have a 15.5 lb one and i have to rev it alot higher to get it to engage smoothly. When i dont it chatters and usually shortly after my clutch squeaks.
Old 03-09-2010, 03:17 PM
FUH Q's Avatar
Excuse me not knowing this but what do you mean by "slip it"
Old 03-12-2010, 11:20 AM
FUH Q's Avatar
Bump!
Old 03-12-2010, 01:35 PM
SPEC-01's Avatar
What stage clutch is in the car? I ask because some materials are more prone to noise during engagement than others are.
Old 03-12-2010, 09:13 PM
FUH Q's Avatar
Im not sure but I think its a lower stage because the clutch feels pretty light.
Quick Reply: Clutch sounds like a turkey!
