p1635????
Old 03-08-2010, 06:28 PM
99slobird's Avatar
Default p1635????
please tell me what this is
Old 03-08-2010, 06:49 PM
eseibel67's Avatar
P1635 - 5V reference voltage to sensors low.
As always, check all fuses first. If all o.k., you might have a bad wire somewhere.
Old 03-08-2010, 06:56 PM
BOA279's Avatar
It is a 5 volt reference 1 circuit fault. The PCM uses a common 5 volt circuit as a sensor feed. This particular feed only goes to the A/C pressure sensor, EGR valve and MAP sensor. Check for loose/dirty plugs or wiring problems. It only has to do with those 3 items, wiring or the PCM.
Old 03-08-2010, 07:37 PM
99slobird's Avatar
finally someone with an answer ill check these tomorow and get back with yall
Quick Reply: p1635????
