Need some fuel line bent
Does anyone know where I can have some 3/8 fuel line bent up for my C4? I'm close to having my LS swap running and despite successfully bending up some 5/16 line for my trans with my cheap bender the 3/8 won't bend without flattening.
Thanks!!
Thanks!!
I just finished doing a LS1 swap into a 91 RS. I used the fuel tank and fuel lines out of a '99 z28. I picked up a cheap pipe bender from Harbor freight to bend the fuel lines and the power steering lines to fit (fuel feed line is 3/8"). Worked pretty well. But if you are trying to straightenout kinks, it will flatten the pipe.
