T56 Trans.... What Are The Weak Points?
Old 03-09-2010, 11:23 PM
02CamaroZ28Slp's Avatar
Exclamation T56 Trans.... What Are The Weak Points?
I have an 02 Camaro Z/28 SLP. i re did the motor this winter and now i got a 383 LS1 hopefully close to about 600-650HP..... Now my question is what parts in the T56 Trans do i need to replace to handle the power????? I want to stay with the stock Gear Ratios and the 6 speed but also dont want to spend a million dollars...... Thanks for your help.
Old 03-10-2010, 01:33 AM
Wnts2Go10O's Avatar
slider keys, shift forks, and blocker rings are the major ones i believe
Old 03-11-2010, 10:46 AM
thanks man.... any idea on the out put shaft or anything on those?
Old 03-11-2010, 07:48 PM
99LS6SS's Avatar
Should be fine on shafts but if you're worried upgrade to the Viper main shaft for added protection
Old 03-12-2010, 02:00 AM
mrx8200's Avatar
If I ever upgrade my trans this is where I'd do it:
http://www.tick-performance.com/tick...ackages/fbody/
It's a great price and you don't have to worry about screwing something up doing it yourself. Even if you don't rebuild through them it gives you a pretty good list of what parts to put in.
Old 03-12-2010, 10:17 PM
98ws6&02gtp40th's Avatar
how hard is it to change that stuff, im thinkin of doing a sts ket on my next ta
Quick Reply: T56 Trans.... What Are The Weak Points?
