upper panhard support?
Old 03-10-2010, 10:52 PM
98 4X4 burban's Avatar
Default upper panhard support?
upper panhard support is what i am going to call it, it is the flat piece that bolts above the panhard rod on the pass side of the car then across to the driver side with 3 bolts.
is this really necessary when upgrading to full tubular rear suspension?
Old 03-10-2010, 11:26 PM
Taken4granted's Avatar
are you going to replace it with a new tubular one? or watts
Old 03-10-2010, 11:31 PM
Breathing Fire's Avatar
I might be wrong, but I think it is a weight bearing bar. I don't think I would go without.
Old 03-11-2010, 05:19 PM
Taken
i have all tubular rear. if they hake a tubular replacement for this i will chande it if it is in fact necessary to have it.
breathing
i have seen it both ways but it looks really weak and flexable to be weight bearing.
Old 03-11-2010, 08:24 PM
mitchntx's Avatar
If you remove it, the stock location PHB has a ton of leverage on the passenger side mount. The ONLY thing holding that mount are the spot welds. It will flex and eventually rip/tear out.
The upper mount is indeed weight bearing, but in compression and stretch. It reinforces the passenger side mount.
So yes ... you need it.
Old 03-12-2010, 07:24 AM
UMI Sales's Avatar
Hello
Like mentioned above it is a weight bearing part. And it is a must! If you are looking for better clearance for exhaust then I would suggest a relocation pan hard bar. Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/catalo...p86pg5g7il0qq1
If you have any other questions feel free to ask!
Thanks
Brad
Quick Reply: upper panhard support?
