ls1 swap into 69 camaro help
hey guys i got a 2000 ls1 motor that is drive by cable. I didnt get the pebles so how would i go bot hooking up the cable to my gas peble are will that not work are what i got to do? if any one have any input i would be greatfully
jason
jason
I'm walking the same line right now. You can use a pedal assy. from the 6 cyl. cars from 1st gen Camaro's or Nova's (forget what years), or the cross-ram pedal, all made for throttle cable. Classic, Ricks and other 1st gen. suppliers carry them for around $50.
Hope this helps, I am no guru, just following other's lead!
Tom
Tom
Tom
Tom
what cable did u use ? an did it bolt up to the tb of the ls1 an did u have to chang ur Accessory drive any to fit the k member? one shop told me i got lucky cuz the 2000 camaro accessorys will fit with out cut the k member are goin with aftermaket brackets . the only thing that wont fit is the ac unit an i dont want that anyways. so could u let me know what u did on this problem to thanks
I'm using a lokar cable, but it is still in the package. I still need to buy the pedal assy. I'm using a Wayne Due C4 subframe and am using the F-body oil pan without modification wit plenty of room. Also, plenty of room for the Alt., but no clue regarding A/C but it doesnt look like it will fit with the engine 1" further back. Sorry I couldn't be of any help on this.
look on lokar web site , they have a ls1 throttle cable assy, the pedal will be separate from it. use a corvette accy/with a kwik perf a/c bracket. i used the brp mounts and notched my crossmember and put the a/c on the lower pass. side. looks alot cleaner than the kwik perf kit
