Questions about my 2002 SS
I appreciate any and all insight that you guys offer..
I bought a 2002 Camaro SS with CME and some other SLP options, with 20,500 miles on it, just two weeks ago.
The car needed some work, Tires all the way around,the ones on their were dry rotted(They were new, it was a shame), I need a new oil pan gasket, a rear differential pinion seal, and brakes and rotors all the way around. I had it inspected at a Chevy dealership before I bought this and the dealer said these items needed to be repaired. Reason being, the car wasn't driven enough..
The seller and I agreed on a price, plus him paying for the fixes. So, I got all the above Items mentioned fixed, but today, I blew my rear end out driving on the highway. I was only going 65mph, I only put 50 miles on this car since I picked it up two weeks ago, so I haven't beat the car, or driven it hard.
My questions are, Wouldn't the dealership known this was going to happen, or be a problem when it was inspected?? Rear end, I'm refering to.
Then when the dealership changed the rear differential pinion seal, wouldn't they notice if something was wrong with the rear end? Or they two different areas of the rear??
The dealership I have it at now, said the rear oil is black, and they have to take it part to check out the situation(It could either cost me 600, or 1600). So when it was first inspected, wouldn't they know the oil is black, and shouldn't they have said something??
I'm just frustrated that I just got this car, and I only have put 50 miles on it, and it's been in the shop more then road.
What else should I have looked at it while it's at the dealership???
I had them change the oil, when it was there on Monday..
Thanks again.
I really appreciate any insight on these matters..
House.
It feels like the first dealership that did the inspection(In another state, where the car was Located), screwed me. Unless, they don't look at all that stuff. On the sheet it says inspected differential and it was fine, so I don't know..
Sorry for the rant, it's be a depressing day.
Thanks again.
House.
A car with only 20,500 mi should not have black oil in the diff. I wonder if the mileage is legit or someone replaced the diff fluid with the wrong type at some point. To really report on the condition of the rear, the inspection cover would have to come off. At that point, excess metal (shiny) flakes or chunks (obviously) indicate a problem. If no prob noted, someone would still have to pay for new fluid, gasket (or sealant) and additive - this would be on the inspection/repair sheet for sure - mechanic would want to be paid for his time! Cars that sit do experience leaky gaskets due to shrinkage, the coolant turns acidic (with associated problems), rotten tires as you noted, but the rear having BLACK oil and then blowing up? An inspec with cover off WOULD have revealed broken spider gears etc. Like "bene" said, try sourcing a new/used rear or a better one -I know, its just money... ha ha. Yea, this sucks, makes you second guess so many things! Youll get er sorted!
You probably don't want to hear this but best bet would be to upgrade to a 9 inch or 12 bolt and forget about your old rear. Not a cheap fix but you will be safe to add more power in the future.
Thanks again.
House.
Thanks again.
House.
Roadhouse!
That does suck, but I agree with the 9" or 12 bolt. Stealership is gonna bone you hard on the price of the 10 bolt, might as well spend a bit more and upgrade.
Thanks guys for the insight and thoughts..
Yea, the stealership has me by the *****, I don't really trust any other mechs to do the work, not that I trust the dealership either, but I don't have the tools or experience to do this work. I been reading up about the rear ends, they seem to be weak from the get go from GM..
Do you guys think I should be looking for anything else to fail or break on this car, since it's been sitting for a while. I'm just really bummed out, and expecting something else now to break.. I know anything can break at any given moment, but maybe I should have other things looked at too.. I just want to get out and drive..
Thanks again..
House..
I liked the Roadhouse comment, that was a great movie.. lol
Thanks again..
House..
Thanks again..
House..
Thanks again..
House..
As for the car, fluid change everything. Really only way to be safe.
Thanks again..
I really appreciate it guys for all the posts...
I'm not sure if your serious or not, so I will say No, I'm not sure. I think though that would show up on carfax report right?? Since it would cost a few thousand to fix.. I mean the interior is immaculate, the leather is still stiff, and smells brand new..
If you were going for the sarcasm angle, like on the carfax report commercials, then, lol.. If not, why would say flood????
Douchebag On The Tree
If you're dying to spend the almost 2G's for a new rear or you are gonna mod like crazy, I would do this and never look back/worry again.
LS1Tech Administrator
Received 1,486 Likes
Addtionally, I'm surprised to hear that the diff fluid was so dirty. I changed mine at 11k miles when I bought the car, just to inspect the rear, and the original fluid was super clean. Can't see how it'd get that dirty in just 9k more miles. My guess is, if the pinion seal was leaking badly enough, the diff was probably low on fluid for a while now. This low fluid condition may have lead to excessive gear wear and overheating of the fluid (explains it being darker than it should) resulting in your broken rear.
Overall, I wouldn't have any fear of a super low mileage car so long as it was stored and cared for properly. Only real concern is the coolant, IMO. I would flush that ASAP if it's never been done. I do regular coolant changes on my '98 just to avoid the sludge effect that comes with old dexcool. So far my routine has worked great - 12 year old cooling system with 100% stock parts that's clean as a whistle, operates perfectly and doesn't leak.
Diff seal, brakes, and pan gasket shouldn't go bad from a car that sits like yours has. My '98 has only 15k miles and I don't have any of those issues.
Exactly what I was thinking. And just go ahead and change ALL your fluids so you can get on a maintenance schedule....
Thanks for the posts guys. I appreciate it..
Yea, I will have the fluids changed. I had the oil changed monday. So I will get the Coolant system flushed, as well as, the tranny fluid..
The differential fluid will be changed when they fix the rear end..
Should the breakline fluid be changed as well?? Or just the above mentioned fluids are fine??
Thanks
House..
This is a great site, you guys are very helpful and friendly..
Thanks
House..
