Question about bleeding...
So tonight I did the drill mod to my 2000 Z28. When I went to bleed the system I did it like the write up says which was depress clutch - open bleeder - close bleeder - release pedal. So upon releasing the pedal everytime (about 10-15 times) we always had to pull the pedal off the floor. So I ended up having to pump the pedal with the bleeder closed about 50-60 times until the pedal was normal feeling. Is this normal?
