Drag Racing Tech
What Kirkey pro street width to get? And 5 point harness length?
Old 03-12-2010, 12:45 AM
airfix's Avatar
Question What Kirkey pro street width to get? And 5 point harness length?
Hey guys, I'm about to order a set of kirkey seat but am unsure on what width to get. I was looking into the 17" wide, but after doing a search it seem they will be to wide for me. I'm 20 y/o 6' 190lbs with a 34" waist, so leaving a little room to grow might be a good idea, I doubt I'll ever be over 220 and 36" waist. What width do you guys recomend? The car will be driven on the street a fair amount so I don't want to be squeezed into them.
Also I'm going to need a pair of 5 point harnesses aswell, but am unsure of the length I'll need. They will be mounted to the rollbar cross bar. This is the set I was looking into.
http://www.summitracing.com/parts/SIM-29112BK/
Would these work? What would you guys recomend.
Thanks in advance guys.
Ryan
Old 03-12-2010, 10:52 PM
airfix's Avatar
anyone...?
Old 03-12-2010, 11:11 PM
1lejohn's Avatar
The 17" is what you want. I'm 5-11 185 and they fit good. Had some Corbeaus that were narrow and never could get comf. in them. I bought some high density foam to add for padding. I cut it to fit under the snap on covers that Kirkey sells. The belts are adjustable, not sure of the length that I bought.
Old 03-12-2010, 11:14 PM
Man-Crush Warning
01sscam's Avatar
I run a 17 on the drivers side, and an 18 on the passenger side, in the process of picking out a harness.
Old 03-13-2010, 01:27 PM
AChotrod's Avatar
Ive been thinking about this also, but Im only 150# would 17s be to big?
Old 03-13-2010, 01:33 PM
ndfrsd6's Avatar
^^^mike i have 17's in my car you should come by and test them out
Old 03-13-2010, 01:38 PM
INTENESS's Avatar
Go with the 17's they should fit you,
Old 03-13-2010, 01:52 PM
7 Second Club
Phil99vette's Avatar
Why dont you measure and get the one that fits you? Kirkey has a measurement process on their web page.
Old 03-13-2010, 02:08 PM
airfix's Avatar
Thanks, looks like the 17 will be best for me. Now just to figure out what harness length I need.
Old 03-13-2010, 02:11 PM
airfix's Avatar
Mike, here's the kirkey measurement page.
http://www.kirkeyracing.com/index.ph...LID=customShop
Old 03-13-2010, 02:50 PM
7 Second Club
Unless I'm confused most of the harness's are adjustable.
Old 03-13-2010, 03:53 PM
94Z28rag's Avatar
I'm not sure why you're wondering about harness length. Get a set of Impact harnesses and you're good to go.
Old 03-13-2010, 05:09 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I had 17's, am 210 lbs and 34 waist.
Old 03-13-2010, 08:44 PM
airfix's Avatar
Ya I knew they were adjustable but wasnt really sure because I've seen different lengths advertised. I've never bought harness before thanks for clearing that up.
Ryan
Old 03-14-2010, 12:17 PM
AChotrod's Avatar
Thanks!!!
Tom,
Ill see ya soon to check them out.
Old 03-14-2010, 12:23 PM
Ryans_pewter_ss's Avatar
How did you mount your 18" kirkey on the passenger side? I'm having trouble getting mine to fit, hits the rollbar and brackets don't seem to be wide enough
Old 03-14-2010, 02:12 PM
Man-Crush Warning
01sscam's Avatar
I'm using the racecraft brackets, I'm still trying to get my passenger one to fit in there, I'm having trouble as well. I think I'm going to have to do some slight grinding on the seat.
Old 03-14-2010, 04:08 PM
sweetbmxrider's Avatar
i have a 15 inch kirkey, its not the pro street though. im 5' 11" 155lbs 32" waist. its a comfy fit
Old 03-16-2010, 10:49 AM
1lejohn's Avatar
Mine was a tight fit on the pass. side. You can't move them back to the rear very far. I bought the race craft brackets and had to modify them to fit. It was a lot of work. I'm thinking about getting some other seats. Any ideas?
On the drivers side I used the stock non power tracks to mount them. The race craft brackets had me sitting to low and flat. Mignt do that on the pass side also.
Quick Reply: What Kirkey pro street width to get? And 5 point harness length?
