Suspension and tires experts step in please
I'm trying to figure out what is the problem with my car
I don't relay know if i had a problem or this is normal
when i WOT from 45 m/h in second gear in the high way my car rolled to left and if I keep WOT I lose the control because it goes side ways
I have M6 GTO 500 whp 490 tq
I have the following suspension mods:
-King HHD rear spring stock height with a rate of 1000 lbs/in
-Lovells front springs
-Lovells shocks and struts
-Hotchkis sway bar second stiff rear and mid stiff front settings
-front RR bushing
-Diff insert
-new Nitto 275/35/18 NT555 @ 28 PSI
-Control Arm bushing and some other
should i put some Hoosiers or is it sway bar settings problem (what is best for straight line launches ?)
what do you think ?
any help will be appreciated
-front RR bushing
-Diff insert
what do you think ?
