fuse box?
Old 03-12-2010, 02:42 PM
willis b otch's Avatar
Default fuse box?
sorry not sure if this is the right section.
I've electrical issue. I just change my alternator. blew my battery then I repalced it now my car reads 18v
popped the fuse box (the box towards the headlight)
there wasnt a fuse in empty spot.
I tested all the eight fuses including that empty spot, none of them lit up but the four big ones did.
so I replaced the ones that didnt work still nothing lits up
I noticed theres not a prong in the (LH HDLP DR)
which is that emty one in the pic below.
Is that right or am I gona have issues?????
cause the car drove fine till I had to change that alternator
Old 03-12-2010, 03:12 PM
nevermind I got the fuses to lit up but excepted for one
the (pcm bat) now Im really worried which I hope my pcm isnt fried.
any ideas what I should do
Old 03-12-2010, 07:03 PM
fleetmgr's Avatar
The only way to know is to put in the new fuse, and see if everything is working ok.
Old 03-12-2010, 08:05 PM
biggb1783's Avatar
[QUOTE=willis b otch;13022868]sorry not sure if this is the right section.
18V is not right. 13 - 14.5 is ok. Anymore is not. I would have that alternator tested, i bet the internal voltage regulator is nfg.
Quick Reply: fuse box?
