View Poll Results: Which intake should i get?
Vic Jr.
5
41.67%
FAST 102mm
7
58.33%
Other
0
0%
Voters: 12. You may not vote on this poll
Vic Jr EFI vs FAST 102mm
Sadly this thread may not be what a lot of you may think from the title alone.
Essentially I am trying to decide on an intake for my setup. My car has the following mods;
FM13 - 230"/232" .595"/.585" 112LSA
Stage 3 ported 243's
ASP u/d pulley
LS7 clutch
Pacesetter LT's
Tick Master
3" true duals
ARP bolts everywhere
Full suspension
SLP lid
Nitrous Outlet 92mm plate kit - 150 shot
and a ton more, but still a 346 which may make both intake choices not the best.
I realize some of that doesn't have anything to with HP, but i just copy/pasted it on here from another site i am on.
So my choice of intake is between the Vic Jr, with a 92mm TB and elbow(yes i realize the 4150 makes more power)
Sort of like this setup;
http://www.cardomain.com/ride/2977048
http://www.dallasperformance.com/DPC...lane/index.htm
However i would be using it with my nitrous kit and probably add this:
http://www.nitrousoutlet.com/installs/install.asp?id=88
For arguments sake ill assume we all know what the FAST 102mm looks like. Do you think they are both overkill?
I am just so lost on exactly what i want for the car, so im coming to you all for suggestions.
ASP u/d pulley
LS7 clutch
Pacesetter LT's
Tick Master
3" true duals
Full suspension
SLP lid
I would go with the FAST. I have a slightly more modified 346 with the Vic Jr and think I'm switching over to the FAST. The Vic Jr is less expensive, however. If you might be interested in a slightly used Vic Jr with that same elbow let me know.
