Need your help!!
Need your help!!
I read the sticky about how to unlock the monsoon radio for my 02 SS. Unfortunately for me.... It wont work! I just bought the car and the lock has been on since.
I press 2 & 3 and get the first 3 digits of the code.. Then it tells me to press the am/fm button. And nothing! I tried pressing it, holding it down for 10 seconds, 30 seconds, a minute..... and then even 2! What am I doing wrong here? I "pressed" the am-fm button and got nothing!
Heres my radio (IDK if theres different ones... This is just a pic I found)
I'm pressing the button under the "eject" button... "AM-FM"!!!
Any help would be appreciated! LOL!
Ungrounded Moderator
It's possible that the second set of three numbers is the same as the first set. That would make it seem like nothing happens when you press the AM-FM button. I would try calling the toll-free number and entering those numbers to see if it gives you a valid unlock code.
Yeah its a hassle but I call the number and see what happens. Also either make sure you write down the code in a good spot or change it to something you will remember. Ive had to call them 3 times because I kept losing the code, so finally I changed it.
Does anyone remember if the HU came with a sticker on it with the code when you bought the car brand new? I seem to remember leaving the sticker on the HU until it fell off or I knocked it off cleaning.
I press the 2 and 3 buttons and come up with "122"... Then I release from the 2 and 3 buttons.. And hold the AM/FM button.. And nothing happens.
Are all the unlock codes the same?
so you can get the first three numbers but the second set wont show up? You dont have to hold the am/pm button I think you just press and let go and the next 3 numbers should show up.
