Anybody dead hooking on the street?
Old 03-14-2010, 09:13 PM
nosaj's Avatar
Default Anybody dead hooking on the street?
I want to know anybody that is hooking on the street setup, suspension and tires?
Old 03-14-2010, 09:23 PM
Restricted User
1BAD_LS1's Avatar
i can hook on takeoff pretty good if i stay out of boost, but then brake free after i think i need to make more adjustment on my tq arm...
I have 28" mt on 15" rims and skinnies up front, 9" rear, spoohn tq arm, bmr lcas panhard STB.....
Old 03-14-2010, 09:24 PM
bayer-z28's Avatar
Nope...
But I get my NT05's back from mounting tomorrow.. Had to drop em off and the shop was slammed so I'll get em back tomorrow. I'll have to wait and see if I hook up when the ground gets warm.. At the track I have to almost leave off idle on my old worn out GS-D3's @ 2.06 60ft at best on second run ever.
Ride details as requested and power in sig:
Eibach prokit (Yeah I know)
SLP Bilstiens (Yeah, I know)
Strano FT sway
Hotchkis LCA's w/ RLB's -Parallel with the ground
BMR ADJ TQA
BMR ADJ PHB
BMR Tubular SFC's
285/35 tires.
Old 03-15-2010, 07:39 AM
UMI Sales's Avatar
Hello
To help hook better on the street. I would suggest looking into a new set of lower control arms and relocation brackets. And a good adjustable torque arm to allow you adjust the pinion angle. And if you are close to 425-450 HP I would suggest getting the arm off the rear of the transmission with either a relocation cross member or a tunnel mounted torque arm. And you will definitely need a good set of tires such as a DR. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...bgc81p7138k8t5
http://www.umiperformance.com/catalo...ex&cPath=7_115
http://www.umiperformance.com/catalo...ex&cPath=7_116
If you have any other questions feel free to ask!
Thanks
Brad
Old 03-15-2010, 03:57 PM
BottleFedZ346's Avatar
I have dead hooked on the street on spray with barely any suspension mods sfc's/adjustable panhard bar/12 bolt.....Tires are 275/50/15's hoosiers
Old 03-15-2010, 07:01 PM
nosaj's Avatar
All I have right now is tubular subframe connectors and drag radials on 17s
Old 03-15-2010, 08:18 PM
bayer-z28's Avatar
^ ahh crap.. Forgot to add that to the list above. I forget over time what I have in my car.
Old 03-16-2010, 12:32 AM
92SilverSHO's Avatar
I don't dead hook per say but my car won't tires in any gear at any rpm, it just goes. My car will only spin tires if i pop the clutch.
Quick Reply: Anybody dead hooking on the street?
