Drag Racing Tech - Stock hood weight?
View Full Version : Stock hood weight?
Damage Inc.
12-31-2003, 06:11 PM
What does a stock Z28 hood weigh? I want to get a VFN SS hood that weighs 25 lbs. and I want to know if it's worth it. I tried posting in the weight reduction forum, but I got no responses. Thanks. ;)
Big Mike
12-31-2003, 06:24 PM
Be sure to check out the Group Purchase going on right now with VFN!!
http://www.ls1tech.com/forums/showthread.php?t=123970
Terry Burger
01-01-2004, 03:41 PM
Stock is 48#, most pin on fiberglass hoods are around 16-20#, and most bolt on fiberglass hoods are 35-40#.
Larry
01-03-2004, 05:47 AM
My stock hood weighed 48 pounds. The 18 pound stated factory looking bolt on VFN weighed 22 pounds.
The edges look pretty bad on the VFN. You need to have a shop that specializes in fiberglass to fix it if you want it to look good.
verbs
01-03-2004, 02:00 PM
The edges look pretty bad on the VFN. You need to have a shop that specializes in fiberglass to fix it if you want it to look good.Was the 22lb weight before or after you painted it? Was that with or without the latches on it? did you weight it after painting and before?
Larry
01-03-2004, 02:23 PM
22 before paint. 22 1/2 pounds after painting. Weights without latches.
verbs
01-03-2004, 06:52 PM
Thanks Larry!
Damage Inc.
01-04-2004, 07:27 PM
So you say the VFN hoods are pretty rough huh? Hmm, I'd like to shave some more weight off the nose, but I don't want the car to look bad. Does any run a 2" VFN Cowl on their Camaro? Pics? Problems? Experiences? Thanks.
LIL SS
01-06-2004, 11:01 PM
My VFN Pin on looks great. I saw the pics of Larry's when he posted them. The Bolt on is much thicker then the pin on. I don't think what larry is talking about would be noticable with the hood closed, only open.
Larry
01-17-2004, 07:08 AM
You can see the sharp edge with the hood closed but it is probably acceptable for most. If you are very particular with your car then it would probably not be acceptable.
If I had it to do all over I would have a fiberglass shop fix it before painting!
trax
01-17-2004, 06:52 PM
well... VFN is a fiberglass shop... as a customer couldn't one just ask for it to be de-burred or cleaned up?
Larry
01-17-2004, 07:34 PM
Why should you have to ask for it to come made right? I would have gladly asked had I known it was so bad. They should let buyers know it comes needing more work or offer to do the work at extra charge!
trax
01-17-2004, 08:40 PM
My bad... I didn't notice your location. Yeah, if you're in Texas it's kinda of a PITA to have VFN fix the problem. I will probably be getting their flat LT1 bolt-on hood either this summer or the summer of '05. It would be interesting to see how they would react if someone local came in to pick up their hood and said they weren't satisfied and wouldn't buy it until it was "fixed".
Thanks for the info Larry :)
Damage Inc.
01-18-2004, 02:24 PM
I live within an hour of VFN and heard that they've cleaned up their designs quite a bit since the older burred days. Would a bolt on 22 lb. hood be worth the time and hassle over a stock hood?
