LT Headers easire to install with trans out?
Old 03-15-2010, 03:39 PM
ssjTAdriver's Avatar
Default LT Headers easire to install with trans out?
The m6 on our 2000 TA will be out and I wondered if it would make it easier to put in the LT headers from SLP. They is also an off road y as well. I'm assuming yes. Thanks for any replies.
Old 03-15-2010, 04:00 PM
Fabian's Avatar
No, not really. The tranny isn't really in the way to start with.
Old 03-15-2010, 04:14 PM
Duffster's Avatar
The biggest issues with installing long tubes are the low low section of the shock tower/body to engine on the passenger side and the steering on the drivers...
Old 03-15-2010, 04:22 PM
SuperSport01's Avatar
Try putting lt's on an LT1 car then on any other car on earth, you will never complain about installing lt's again lol
Old 03-15-2010, 04:49 PM
Z28_LT1's Avatar
This is VERY true. I did mine on my LT1. nothing but bloody knuckles and cursing. got them on though.
Old 03-15-2010, 05:12 PM
Mart00SS's Avatar
I dont see it being any easier with the trans out. Trans is not in the way at all. Depending on headers its usually just the drivers side that gives people a problem and either the steering shaft or motor mount pedistal get in the way.
Old 03-22-2010, 10:08 AM
Okay, I was hoping it was. I will search tips on how to get the headers in easier. Thanks guys!
Old 03-22-2010, 10:19 AM
LaVy's Avatar
I installed longtubes headers on my lt1 with the trans out and I thought it made it a lot easier when working from the bottom just because it gave me so much more room to work. It also gave me a better angle to slide the headers in place (from bottom). I would say if your trans in already out, to go for it now.
Old 03-22-2010, 10:24 AM
eatlead's Avatar
Trans has nothing to do with it. All depends on which header your using as to how the installation will go.
Get the car in the air high as you safely can, 30" minimum is what you need they go in almost vertical.
Some will require the starter or the steering knuckle be moved.
Old 03-22-2010, 10:32 AM
Dskeet6's Avatar
you need to have the car high enough to angle the header up in and not hit the primaries on the ground.
Old 03-22-2010, 11:26 AM
Mart00SS's Avatar
Originally Posted by Dskeet6
you need to have the car high enough to angle the header up in and not hit the COLLECTORS on the ground.
fixed
Old 03-22-2010, 02:29 PM
Dskeet6's Avatar
Originally Posted by Mart00SS
fixed
Haha thanks bud
