Anyone Make a 12'' Stealth Box ?
I know people have made them and I think one place sells them but can't remember who. If anyone has any info on where to get one.. I want to know
This is for the drivers side well.
I've got one that I need to sell.
TZ: 12" subwoofers are CONSIDERABLY better than 10"s, even though most 12" want more airspace than we can give them in this application, but there are still some awesome ones that work here.
No, there aren't. When comparing SOME 12s, there are sometimes some 10s like the TC Sounds/Audiopulse LMS Ultra that hit harder, but what you said is not true at all because a 12" LMS Ultra hits harder still. I doubt that anyone on this site uses a 10" subwoofer in a stealthbox that can handle what my Fi Q12 did, even though it's not the best 12" (though it's still very good). Besides, most people on this site are using junk like Alpine Type R.
Twelves are usually no better than a ten of the same style/series of subwoofer. they all share a common design, usually they have the same voice coil, same motor structure, and sometimes even the same spider. The only gain the 12 would give is a little more cone area. The ten would have an advantage because it requires slightly smaller volume.
Er, Ok then considerably more cone area would be the only advantage. My main point was there's not that much of a difference in the quality or build between most 10" and 12" subwoofers. I'm not trying to start an argument I'm just saying that a 10" sub does have some advantages over a 12" sub in certain applications, namely ones that are limited by volume.
I did say SOME 10's will outdo 12's, a lot of factors come in to play though.. Anyway, here's an example of two 10's that a lot of 12's couldn't do:
http://www.youtube.com/watch?v=U7N0r2TXc_M
and
http://www.youtube.com/watch?v=igERs...eature=related
But it all depends on box type, power, tuning, etc..
Back on topic: OP, did you find a pass. side stealth yet? If not, you could also think about possibly making one, may be a little cheaper long as you have an idea of what to do.
and
