ls7 motor on c6
ls7 motor on c6
hello
if i installed an ls7 short block on a c6 ,, would it be the same as the zo6 power,, i mean in a street racing ,,
ls7 short block
ls3 heads
small cam
6spd
whatis the power expected to the rear wheel
ls7 short block
ls3 heads
small cam
6spd
I don't know if you'd lose that much keeping a wet sump Where you are going to lose power is if you go with the LS3 heads and intake. If you're that concerned with making Z like power...Save up and put an LS7 head and intake on it or go with the FAST 102 if you are only planning on running a mild cam.
There are several cam only LS3s out these @ 500 rwhp so I bet with a bigger cam he will make good power. Stock for stock the LS7 only makes about 60-75 rwhp more than a LS3.
My LS3 Dynoed 378 stock and my ls7 did 445. My LS3 was an auto though.
I agree but Hinson made a LS3 based 427ci that punted out 600rwhp in a RX7. With the right cam you should have a pretty stout setup. I think LS7 heads still are kinda $$$ so it may not be worth it.
