What style harness to use with roll bar/cage setup
For right now plan on using factory seats with an 8 point setup. I am purchasing the Burkhardt crotch strap setup. Looking at an Impact 5 point bolt in?? Not sure if it is preffered to wrap the crotch strap and shoulder straps but bolt the side belts to the rear seat bolts?? Let me know how you guys installed them. Thanks.
I wraped the shoulder harness and crotch starp, bolted the lap belt onto the stock lap belt bolts. I kept the stock belts also for normal driving. The only problem with the stock seats are that the belts slip off the seat back
I'm going with a set of RCI wrap arounds for the shoulder and crotch once I get my 6 point in, I think I've heard that the trans am seat will accomadate the shoulder belts better the Camaro seat would and Wolfe sells a bolt in bar that can be used for a wrap around crotch setup.
