Helicoil came out of oil drain plug hole
I was changing my oil this weekend and when I tightened down the bolt it seemed like it stripped out. So I pulled the bolt back out and the first ring of the helicoil came out with it. I pulled the rest of the coil out with the bolt when I tried again.
My question is can I buy the same size helicoil (12 X 1.75) and put it in? Will I have to redrill and retap the hole or can I just install then new one without all that?
