AC and Heat Help!!!!
Here is whats happening. No matter where the selector ac/heat switch is the air only comes out the center vent that is up on the dash. Im not sure where to start trouble shooting. All fuse seem to be good. The fan works on all 3 speeds but nothing changes if you put it on max AC. I'm thinking it maybe a derectional air flow that is not switching but how do you check and how to get to it??
Any other ideas? Anything will help. I'm sort of stuck so please someone HELP.
Thank you:confused
Thank you:confused
All the doors that direct airflow inside the heater box are vacuum controlled. You probably have a line that's become broken/disconnected. Start by checking where it comes off the back of the intake manifold.
Fixed, Thank you
Check behind the intake to see if the vacuum hose fell off that feeds that set of lines their vacuum.
Its gonna be hard to reach back there to feel for it if you don't know where it is. Try to get a picture of the rear of an intake so you can see what your reaching for.
