bump stop bolt size?
Old 03-16-2010, 05:04 PM
z28_theantirice's Avatar
Default bump stop bolt size?
Finally getting around to some bump stops back on my car, anyone know the size bolt I need?
FYI - I already searched
Old 03-30-2010, 11:25 PM
trippinholyman's Avatar
I know that its a 13mm bolt. Not sure on the thread or pitch or anything like that. I actually just replaced my (completely fubar) stock ones with some poly Jeep universal ones. Driver side was easy. Passenger side was a pain in the ***. I had to make sure I got all the old rubber off. Used the handle of a ratchet and a 5 lb sledge. Took some vise grips and rolled the lip out so that it would work. Got it rolled out far enough that I could thread both bolts and torque it down / smash it so it would be level/flush. Had to trim a piece off the passenger side too, was rubbing the tire. That was done with a razor blade. Put the wheel back on and torqued the lug nuts and done.
I'm not sure if the guy I got them from is still a sponsor, but if you want to know where I got mine from send me a PM. The kit I bought came with all the hardware you needed.
