Different sized endlinks for a lowered car?
Old 03-16-2010, 11:33 PM
madhatter's Avatar
Default Different sized endlinks for a lowered car?
I remember reading a GMHTP article a few years back about going to a longer end link if you are lowered. Any truth to this? I am about to install a 32mm sway bar and would like to replace mine when I do it.
Old 03-17-2010, 10:19 AM
SS SLP2's Avatar
bump.
Old 03-19-2010, 11:36 AM
madhatter's Avatar
bump.
Old 03-20-2010, 02:24 AM
99Bluz28's Avatar
You'll want shorter, not longer end-links.The rear end-links are the ones you'll want to change.
Old 03-20-2010, 06:20 AM
the_merv's Avatar
I'm running the stock sized End Links for both front and back..I don't have any problems.
Old 03-20-2010, 07:12 AM
leadfoot4's Avatar
If you lower the car a significant amount, you'll need a shorter end link, as the object is to keep the "arms" of the sway bar as close as possible to being paralell to the ground. However, you can get into angularity problems with the links, if they are too short.
Quick Reply: Different sized endlinks for a lowered car?
