Is this Possible? (HPTuners experts enter)
Okay,
Been trying to figure out how to get an auto tune onto my car without spending hundred dollars on getting my PCM flashed from a manual to an auto.
Right now I do have the pcm licensed with a single vehicle license which right now it has a manual tune on it. Can I go ahead and license an auto-file from the repository and then flash it onto my pcm using the write entire function with the vin number changed.
Thanks,
Tilly
Thanks,
Tilly
You could just copy all the values from the auto file into you manual one. Your computer should already have the stock auto tables into it. If you swapped the tranny in your car and changed the harness there shouldn't be a problem.
I've heard of people doing that and having issues. I know hp-tuners does not give you access to ALL the parameters that are in the OS, so there might be manual tables that need to zero'd out or auto tables that need to be set. But, that will be the first thing I try. Before I try to license another file.
When I did my swap I tried the copy all differences and the trans would not shift. You need to do a write entire to make the transmission changes. As said you will have to license the file so make sure it is the right one. I had mine reflashed with a Tech2 because I could get that done for free.
sure. unfortunately hpt editor still doesn't have a segment swap feature.
to OP: if hpt support don't do it for you, feel free to email me. if you send me the hpt file maybe i can do it for you by email when i have some extra time (will take some hex editing). of course if you just send me the PCM it's a no-brainer bc i could just reflash it with an a4 file, but i want to try it this way to see if i can do it, should be fun...
the file is in *.hpt format. and a VCM serial id # in the file that needs to stay the same. so neither hpt nor EFIlive alone is enough to do it by email.
but actually i just realized couple of simple ways i can do it w/o hex editing any raw binaries. if still needed, email me the file and i'll do it for you...
Compare Tunes.
Copy Trans Segment.
The rest of it is just adjusting all the M6 Engine values for the A4.
i also have EFIlive and am quite familiar with what it can do, thank you. maybe you should read what i wrote again: neither EFIlive nor hpt ALONE is enough to do it by email. unless you want to explain how you are going to swap segments in an emailed *.hpt file using EFIlive...
question is now moot for the OP of course...
yes, it's a key word, despite not being in caps the 1st time. obviously if you have access to the original PCM it's trivial to swap segments if you have the tools. this was clearly about swapping segments in the *.HPT FILE for the OP via email. which i was going to do but again, is at this point is moot bc hpt support already did it for him... it will be even more moot when they add the segment swap feature.
