Replaced Idler pulley & still squealing and chirping!!!!!
Old 03-17-2010, 10:33 AM
FNQUIKWS6's Avatar
Exclamation Replaced Idler pulley & still squealing and chirping!!!!!
Ive started having a chirping and squealing noise at idle and gets louder as the RPMs climb while driving.... As stated ive replaced the idler pulley and its still doing it..... Do I need to replace the harmonic balancer??? it sounds as if the noise is coming from around that area.... This noise is so damn frustrating and its becoming embarrassing when im driving.... please help!
Old 03-17-2010, 12:10 PM
ROCNDAV's Avatar
It could be your AC idler pullies. Rather then buy each one, try this as a quick band aid and find out which one it is:
https://ls1tech.com/forums/general-m...l#post12947844
Old 03-17-2010, 12:50 PM
CaliforniaBoy5's Avatar
+1; did this on mine just to make sure my pulleys have grease; you could take off the belt and spin the pulleys and find out which one makes noise... it will probably round like a roller skate wheel.
Old 03-17-2010, 01:27 PM
u118224's Avatar
It could also be one of the tensioners or even the alternator.
Old 03-17-2010, 01:32 PM
Joshiedoom's Avatar
Harmonic balancer is the very last thing i would look to. Most likely the AC tensioner or idler or belt. Then the other idler then stuff like the alternator or power steering.
Old 03-17-2010, 02:01 PM
the_merv's Avatar
My Alternator Pulley sounds like it's Supercharged..I need to grease it.
Old 03-17-2010, 02:26 PM
FNQUIKWS6's Avatar
Well i took the belt off and spun the pulleys with no weird sound coming from any of them... Its def coming from the drivers side & thats why I replaced the idler pulley down there..... Any other tips?
Old 03-17-2010, 02:39 PM
ROCNDAV's Avatar
If it happens when the engine is running I would still grease all of them as per that article.
If you hear it when you shut off the car then I'd look at the cooling fans.
Old 03-17-2010, 02:42 PM
u118224's Avatar
How many miles are on the car? Have you ever changed the belts? Look at the main serpentine tensioner and see if the marks on the tensioner are within spec. Does the belt seem to have sufficient tension? Your description sounds like a slipping belt.
Old 03-17-2010, 02:57 PM
FNQUIKWS6's Avatar
ok im going to look at the a/c tensioner next..... How do I take that off? What tools are needed?
Also, is this the right part that needs to be replaced? http://shop.advanceautoparts.com/web...S_560864597___
Old 03-17-2010, 03:07 PM
Joshiedoom's Avatar
To save some time/guessing cash, take off the main belt and run the engine for a few seconds to find the sound. If the sound is still there then its the ac. If not then its something else. BTW I have a less than 3k mile whole tensioner setup for the ac ill sell for basically shipping/gas to the post office if you need it.
Old 03-17-2010, 04:07 PM
FNQUIKWS6's Avatar
Thats a good idea man, thanks for the heads up with that.... & if the noise is still there ill def take your offer on the tensioner. Thanks for helping me out & hopefully ill find the culprit soon... Its serioulsy embarrassing driving with this squealing
Old 03-17-2010, 06:13 PM
biggb1783's Avatar
just gonna throw this out there but did you check the water pump pulley?
Old 03-17-2010, 06:16 PM
biggb1783's Avatar
probably the bearing. Just speaking from experience.
Old 03-18-2010, 01:00 AM
the_merv's Avatar
Yea, I plan to pull it apart and check it out.
Old 03-27-2010, 05:00 PM
FNQUIKWS6's Avatar
UPDATE..........
Just pulled off the belt to see if it was still squeaking and sure enough it is.
What should I look into replacing since its not the a/c tensioner?
Thanks!
Old 03-28-2010, 09:49 AM
FNQUIKWS6's Avatar
anyone?
Old 03-29-2010, 09:20 AM
udienow's Avatar
You took off the A/C belt and started the car? Try the main tensioner pulley. I replaced both the tensioner and idler pulley, only to find out it was something on my A/C drive. But if it's still making the noise with the A/C belt off the car, then it might be one of those 2 on the main belt. Also replace the belt itself...
Old 03-29-2010, 09:48 AM
FNQUIKWS6's Avatar
NO i took off the main belt and the squeaking stopped..... Ive replaced the idler pulley.... Im at a loss and dont know where to look... It still sounds like its coming from that area too
Old 03-29-2010, 11:23 AM
ROCNDAV's Avatar
With the main belt off, can you spin each of the pulleys and get any to squeal?
Quick Reply: Replaced Idler pulley & still squealing and chirping!!!!!
