rear bump stops
I wouldnt waste my money on them. Most people who mod their cars either get rid of them or modify them and by that I mean get rid of them or grind them down to fit fatter tires. I got rid of mine few months ago when I lowered my car and have had no probs.
you cant find a 5th gen f body without the bump stops being chewed up.
from what i see, they are hard to find, and most people buy some for a different car (like posted above) and modify them to work
for the 4 years i have had my car, and smashing potholes and everything you can imagine i have never hit the bump stops before
BAD IDEA!!!! If you have significatly lowered your car not running bumb stops can cause damamge if you bottom out on a very rough road or big pot hole. I got a replacement set for mine at GMpartsdirect.com and they're not cheap. Autoparts store doesn't carry the exact replacements and aftermarket one's need to be modded as the mounting surface has tabs. Good luck.
You need to quit putting fat chicks in your back seat ...... in 204,000 + miles I have never hit the bump stops ... but nobody has ever ridden in the back seat either..they rubbed on my wheels so I ground them down to half their size and then later I just took them off and threw them away ... to me they were dead weight..
LOL - Thanks that was great.
If the roads in your area are bad you could have an issue as I did bottom out once with a good pothole as the roads here in Houston suck.
Nobody had them ... Murray's/Oreily's/Autozone/Advance/NAPA. Had to get it on-order from the dealership, believe it was $44 for 1.
And I have an SS, which came with chunky, thick black blocks for bump-stops. Those are no longer available - the dealership only carries base model bump-stops, which are white and taper shaped, narrowing from base-to-tip.
Since then, I've replaced them, and gotten rid of the Eibach springs in favor of BMR. The BMR's, while still low, have much better stiffness and don't hit the stops nearly as often. I think the Eibach's were almost 'riding the stops' in normal driving. Going over a large bump at high enough speed will cause any F-body to hit the stops.. when the stops are there tho, it is not very noticeable. Under normal conditions you don't hear/feel anything unusual, and roadspeed noise will likely cover any 'impact' bump noise.
