Ignition switch?
Old 03-17-2010, 06:48 PM
badinfluencelsx's Avatar
Default Ignition switch?
so i turn my ignition forward, all the lights look fine, no security light lit. i try to start it and it doesnt turn over or anything. lights stay lit, still has power. just doesnt do anything. i assumed it was the key because it starts fine sometimes. sometimes i take the key out and mess with the chip thing and try again and it starts right up. if all else, i just keep trying to start it and eventually it will start. i got a new key from the stealership today, didnt work. so it should be my ignition switch?
also, most importantly, the dealership wants 130 for the ignition switch. autozone/napa 40 bucks.
oreilly/advanced auto 80-90 bucks.. whats the difference? do they not come with the resistor keys? thats a insane price difference to just be competative pricing lol
Old 03-17-2010, 07:55 PM
BOA279's Avatar
This might sound stupid but make sure your battery leads are on tight. I had a similar problem where I got power to everything but it would not turn over because the ground lead on the battery was a little loose. Not enough current flow for the starter to work.
Old 03-17-2010, 08:05 PM
Kevin01Z28's Avatar
When it does start up the security light illuminates right?
Old 03-17-2010, 08:46 PM
yea the battery terminals are tight.. i actually just put a new optima in it cuz im trying to dress up the engine bay a lil. it did this with new and the old battery. i can hold the key forward to where it should be turning the motor and all the lights stay lit. no power drain or loss of power at all.
the security light only comes on when i turn the key forward with all the other dash lights, then it goes away with all the other lights. is does not come on after the car has been started either, no
Old 03-17-2010, 08:53 PM
Kevin01Z28's Avatar
I actually meant when you turn the key forward. When you try to start it do you hear clicking from under the hood or anything like the starter solenoid when it doesn't start?
Old 03-17-2010, 09:06 PM
starter doesnt engage at all. i went out to try to listin for a solenoid or any kind of clicking a second ago, but its working fine tonight.. ill have to get back to ya tomorrow, or the next day, whenever it stops again. its pretty random
Old 03-17-2010, 10:47 PM
HotSilverBird's Avatar
Replace the starter relay............
Old 03-17-2010, 10:52 PM
Fireberg's Avatar
+1 on the relay, its located in the underhood fuse box.
Old 03-18-2010, 04:54 PM
i swapped around the relays, didnt seem to change anything. but every time i go to take a closer look and listin to whats going on, it starts acting right. lol its pretty frustrating
Old 03-18-2010, 07:14 PM
ZigZagZ's Avatar
If you have an M6 (looking at your signature) then I'd try pumping the clutch while starting the car. Recently I had a very similar starting problem, and it turned out to be the clutch start switch. Easy fix, $6.00 part.
Old 03-18-2010, 09:18 PM
yea, ive been trying to pump the clutch too. if its that cheap, i may replace it too just in case. thx
Old 03-18-2010, 09:21 PM
bigj2717's Avatar
If the starter doesn't click at all it can either be the clutch switch or the ignition switch not the key the actual switch further down the column.
Old 05-03-2010, 05:51 AM
update.. ive been dealing with it not working every once in a while but this morning it wont start at all. i was wrong about the starter solenoid. it is clicking. i didnt hear it before because the gauges make a tapping noise at the same time as the solenoid. guess that changes things ALOT lol
