What would cause a T-56 to lose 5th, 6th, and reverse?
Old 03-18-2010, 08:20 AM
raven154's Avatar
Default What would cause a T-56 to lose 5th, 6th, and reverse?
On my way to work I lost all three gears just out of the blue. I have noticed the 2nd and 3rd gear syncros getting a little noisy but never anything with those gears. Any idea? I had a shop do some work on it a few months back and think they may have not done something right. Thanks.
Old 03-18-2010, 09:28 AM
the_merv's Avatar
Countershaft Extention Splines got ripped off more than likely..
I think there is more to the story then just "out of the blue"..
Old 03-18-2010, 09:59 AM
thesource's Avatar
You ripped the lugs off the back of the cluster gear in the unit.
Old 03-18-2010, 10:33 AM
raven154's Avatar
Well it makes about 500 at the tires so..... maybe a little more lol but at the time I just shifted into 5th after a hard pull through 4th and I was out of it when I went to 5th. It was just strange how it was there and then gone. Didn't hear anything at all.
Old 03-18-2010, 12:13 PM
the_merv's Avatar
Well see there is more..lol
You have lost Reverse completely?
I thought that won't kill Reverse though..just 5 & 6 will go out if that little Cluster Gear is tore up.
Old 03-18-2010, 12:38 PM
raven154's Avatar
Yeah I have nothing but the first four gears.
Old 03-18-2010, 12:43 PM
the_merv's Avatar
I'm thinkin you killed the Lugs on the Countershaft Extention.
Old 03-18-2010, 01:59 PM
ArcticMissile's Avatar
This
Old 03-18-2010, 02:15 PM
raven154's Avatar
Well the trans will most likely come out and go to the shop on Monday so I will let you guys know.
Old 03-18-2010, 02:18 PM
Good luck I pray for your wallet.
Old 03-18-2010, 02:30 PM
the_merv's Avatar
What are you guys referring to as the Cluster Gear..the same piece that I'm talking about or the little one that is on the Mainshaft for the 5&6?
I meant to say Countershaft in mine..I had the spline direction backwards till I looked at a pic..
Old 03-18-2010, 06:20 PM
raven154's Avatar
Hey I just noticed you're in Balad. What branch? I've been there a couple times now.
Old 03-18-2010, 09:09 PM
raven154's Avatar
Well the trans is out. Only took about 2-2 1/2 hours from sliding the jack under the car to pulling the trans out. Will be going to the shop tomorrow to find out what I broke!!!
Quick Reply: What would cause a T-56 to lose 5th, 6th, and reverse?
