Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Small Block Build On A Tight Budget =[
Old 03-19-2010, 08:42 AM
LoStOCeAnZ63's Avatar
Default Small Block Build On A Tight Budget =[
I pulled out the 509 big block my dad and i built im going to throw a small block 350 in my el camino im super tight on money i want to get the cam in though so i can worry about everything else as i get more money
this car is going to be driven daily for a little while because its my only car right now
so what size cam can i put in a stock 350 small block that would be good in power ?
Old 03-19-2010, 08:47 AM
oh yeah if i have to change valve springs i can fork out a little more money for that so i can run a bigger cam and i want the car to sound as nasty as possible ! thanks
Transmission is A TCI Turbo 400
3500 Stall Converter
Olds 442 Posi rear end 373 Gears
The whole susp. is set for street/strip
Old 03-20-2010, 05:01 AM
LilJayV10's Avatar
Your cam selection will depend on what cylinder heads, how much compression and what type of intake you are running.
We need to know a little bit more about your setup. If you are going to be running stock 882 heads with 8.5:1 you are going to need a smaller cam and smaller stall.
If your compression is around 9.5:1 you could get away with a 274xtreme cam which sounds very rowdy. If it's your daily driver you might want to drop down to the 268xtreme cam but I would also drop your stall speed too.
Old 03-20-2010, 12:26 PM
In-Zane Moderator
ZONES89RS's Avatar
XE288 comp cam and dont look back, they even work with **** poor compression. Just make sure the install height will be correct on the head.
Old 03-22-2010, 12:23 PM
brandoz28's Avatar
for suspension BMR makes very very high quality pieces, haven't gotten any A body stuff but anything F body i've gotten is outstanding quality
Old 03-23-2010, 06:07 AM
cambirdracing's Avatar
That's not one of those 12 bolt cover/10 bolt carrier rear ends is it?
Old 04-04-2010, 04:20 AM
ok so i finally got a motor for free! its a 350 small block stock bore flat top pistons with a little little dish... flint block not sure what year after looking up the vin i think its a 8.5 compression motor (sucks i know =[ ) i have a set up double hump heads 63.305 chambers 1.94 intake 1.5 exhaust
so with the heads i should be around 9.5 right?
what cam should i run? <
i want sound i want performance and i want high rpms (none of that 5200 rpm crap)
money is the only issue my heads right now dont have any valves so i have to buy some and i still have to bring the block to the machine shop to have everything looked over maybe cleaned up a little does anyone have any idea how much thats going to cost me? <
Old 04-04-2010, 04:49 AM
more pictures...
Old 04-05-2010, 03:41 PM
did you mean the xe284? or 288?
Old 04-12-2010, 02:24 PM
T/ALT1's Avatar
You need to find a set of closed chamber heads to bring the compression up and then add a smaller cam or you are going to be real slow. I would buy a set of used vortecheads for cheap then just upgrade the springs and put some n2o to make it go.
Old 04-13-2010, 03:47 AM
Nate81Camaro's Avatar
This.
Quick Reply: Small Block Build On A Tight Budget =[
