Rubber bushings for LCA's?
Old 03-19-2010, 01:37 PM
Arc00TA's Avatar
Default Rubber bushings for LCA's?
I've been looking at most of the sponsor sites, and I can't seem to track down some LCA's with rubber bushings. I am trying to get adjustable ones since I plan to lower the car, but 99% of the adjustable ones have at least one rod end. I don't really want to have to try and order rubber bushings and have them pressed in. Does anyone know of a manufacturer that makes single or double adjustable LCA's with rubber bushings on both sides?
I'm fairly dead set on rubber since I'm so terribly sick and tired of clunking squeaking rod ends and poly bushings. I grease the bastards every week and still they make all sorts of racket. I would just put the stockers back on except for the fact I want them adjustable for when I eventually get my hands on a set of strano springs.
Old 03-19-2010, 02:15 PM
HAZ-Matt's Avatar
You can either get some Moog 1LE like bushings and press them into the LCAs or there used to be a rubber end that would replace a rod end on those types of LCAs.
Old 03-19-2010, 02:24 PM
Arc00TA's Avatar
I understand that, but I was specifically trying to avoid buying something I don't want and replacing part of it. Thats why I said I didn't want to press in bushings.
Old 03-19-2010, 03:08 PM
Josh18Fan's Avatar
I know BMR sells LCA's with rubber bushings. They don't have them listed on the site, but give them a call.
Old 03-19-2010, 04:29 PM
Arc00TA's Avatar
Really, I didn't know that. Thanks I will call them up. Thats the scoop I was looking for
Old 03-19-2010, 04:43 PM
99Bluz28's Avatar
IMO, J&M 3piece poly-ball LCA's are completely quiet!
The same goes for their Extreme-joints also, but the only thing is there not adjustable.
UMI also has the roto-joints which are also quiet, but they do let a little noise through, but the quality is a lot better then the J&M.
I currently have the roto-joints(non adjustable) on my car, I'm very happy with them!
Old 03-19-2010, 04:51 PM
Josh18Fan's Avatar
Rubber bushing aftermarket LCA's seem too good to pass up. Here's a quote from BMR Tech about them vs their poly LCA's. I'll definitely be ordering rubber bushing LCA's from BMR when I get the money.
Originally Posted by BMR Tech
For what it's worth I have had both poly and rubber lower control arms on my daily driver and the rubber bushing had no effect on the et's at the track(low 12's)
Old 03-19-2010, 05:07 PM
Arc00TA's Avatar
I'm a firm supporter of rubber bushings for my street car. I'm attempting to make it a little more civil and my biggest gripe has been the LCA's so far. I had poly/poly which were alright, and the poly/rod I have now are terrible. I could care less about track times if it makes it so I don't feel every time I drive over a crack in the road. FWIW my solid motor mounts make less noise and vibration than the stupid LCA's did.
Old 03-19-2010, 06:22 PM
Arc00TA's Avatar
Its been a long deployment
Old 03-20-2010, 07:21 AM
leadfoot4's Avatar
If, by some chance, you'd be interested in a non-adjustable, steel tubing LCA, that's been specially made to use OE style rubber bushings, "PM" me. I have a pair for sale.....
Old 03-20-2010, 09:46 AM
01ssreda4's Avatar
I understand the haters of poly. Im quickly becoming one with every suspension piece I add. Adj LCAs with rubber bushings should be marketed more
Quick Reply: Rubber bushings for LCA's?
