Question about the magnaflow merge pipe.
Lookin to change up my exhaust. I have a regular ORY right now. Has anybody used one of these and had a tunnel mounted T/A? Im just wondering if this will work with the correct bends in it or should I send it back and get the Flowmaster merge? Any help is appreciated!!
Thanks-Cody
Thanks-Cody
the flowmaster is a better merge in terms of flow. going with a bigger diameter i-pipe will reduce turbulence, increase flow, and reduce rasp. as far as a tunnel mount TA goes...i have no idea...hopefully some1 will chime in. but if it's possible my vote is for the flowmaster merge.
I think PAT-G uses the magnaflow merge on some of his projects.use the search for exhaust merge.I have seen a couple of threads with TA and exhaust merges fitting .that is what I am working towards.
