where to get bearing pressed on to mainshaft?
Old 03-19-2010, 08:38 PM
MUSTANGBRKR02's Avatar
Default where to get bearing pressed on to mainshaft?
Just like it says where do you guys go locally to do this?
Old 03-19-2010, 09:20 PM
1979rs/z28's Avatar
we can just tap it down with some hammers, j/k man. I can try calling the napa in vanceboro tomorrow and see if they'll do it.
Old 03-19-2010, 09:36 PM
rob69zombie's Avatar
woot woot! Just wanted to comment on Billy's thread.....WOOT
Old 03-19-2010, 09:37 PM
Oh yeah, Cam has a hydraulic press in his shop in Cape Carteret if that helps.
Old 03-19-2010, 09:43 PM
1979rs/z28's Avatar
Nice! Thats what he needs right there
Old 03-20-2010, 01:18 AM
the_merv's Avatar
I do it at my friends shop..he has a press.
Old 03-20-2010, 11:19 AM
KRAZY K 2000 TA's Avatar
why not just heat it up and drop it on?
Old 03-20-2010, 11:52 AM
Dont have the tools.
Old 03-20-2010, 08:25 PM
LS123's Avatar
Get a 12 ton press from Harbor Freight. It's on sale for $79. That is all you need to press anything on and off the T56.
Old 03-21-2010, 10:20 AM
Dammit, i was just there yesterday. It's a hour drive there.
Old 03-21-2010, 06:14 PM
Krom's Avatar
Put the shaft in a freezer, then go get a cheap hot plate, and a cheap sauce pan, put the bearing in and add enough oil to cover it. turn it on med hi and let it simmer. take the bearing out, and drop it on the frozen shaft. will fall right on.
Old 03-21-2010, 07:17 PM
I was thinking that. Except i was going to use the deep freeze at work with a heat gun on the bearing.
Quick Reply: where to get bearing pressed on to mainshaft?
