Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
17by11 zr1 wheels with mickey drag radials
Old 03-20-2010, 09:22 AM
marinetech's Avatar
Default 17by11 zr1 wheels with mickey drag radials
is anyone running this setup if so what size tires are you running and post pics if u have any i want to run this set up on a 99frc for the track but not to sure what size tires to go with.
Attached Thumbnails 17by11 zr1 wheels with mickey drag radials-photo0035.jpg
Old 03-22-2010, 04:24 PM
obi-1's Avatar
I don't have 17x11. I am using the 17x9.5's with 295/45/17 MT's this year. The 275/40-17 MT's are shorter than stock tires. Sorry I don't have any pics.
I did see a pic of zr1 rims and 295/45-17 mt's on a c5 somewhere on corvette forum...
Old 03-22-2010, 07:24 PM
rms-man's Avatar
Here is my DD setup.
Nitto R 315/35/17
These rims stick out past the fender a little bit so if you are lowered consider it might rub. Also, I had to clearance my upper ball joint and spindle to clear the inner barrel of these deep dish ZR1's only on the rear tho. I like them a lot. If you are going to use these for the track then get some MT's drag radials instead.
Quick Reply: 17by11 zr1 wheels with mickey drag radials
