MSD 8950 RPM Activation diagram
Can anyone help me out with this thing? Everything seems to be hooked up right, but it's not wanting to activate the electric shifter solenoid. I can ground it and it works but when I get to the RPM I have it set to shift at (3000 ex.) it won't work.
I've went by MSD's instructions which are for a MSD box but it says it should work with stock ignition.
Anyone have this figured out so maybe I can diagnose this problem?
Out of the RPM Activator:
I've got the red wire to a switched 12v
Black is grounded
White is going to PIN #10 for RPM's
Yellow is the activation wire going to #86 on the relay
Black is grounded
