Double Din in trans am ????
Old 03-21-2010, 06:09 PM
Chaos07's Avatar
Question Double Din in trans am ????
OK so im thinking about getting a double din for the trans am i have a single din that im gunna install soon but later ill do the double and just wondering what kinda of mounting kits yall have used to keep it secure and i know 6LE has the bezel which is good but im jut wondering about mounting and stuff...thanks guys pics would be very very helpful 2
Old 03-21-2010, 07:09 PM
6LITEREATER's Avatar
All you have to do is buy a piece of angle aluminum from the hardware store. Mark the size you need (you are just using it to make two L brackets), cut with a dremel (or metal sheers), put in place, mark where to drill a hole for the factory screws, drill, install.
Now mark a hole for radio cage on the other plane of the bracket, drill and finish installation.
I think I just made it sound WAY more complicated than it is, lol!
Also, I recommend our vinyl or suede wrapped bird double dins over our factory finish style. They cost less and will get to you in a couple weeks instead of a couple of months...
Old 03-21-2010, 07:36 PM
2000SDTA's Avatar
Just wondering, for the vinyl covered bezel, how low do I need to get the deck from the top of the opening? Do I need to cut out the bottom plastic piece that the stock deck rode on right above the hvac controls? Or can the new DD unit I am putting in sit on top of that?
Old 03-21-2010, 07:45 PM
99% sure you do not have to cut the plastic piece, it can depend on the unit you use though...
Old 03-21-2010, 07:52 PM
2000SDTA's Avatar
Pioneer D3, just curious, because it is right up against the top of the opening and it is in there pretty snug, even after I trimmed out the tabs at the top of the opening.
Old 03-21-2010, 08:42 PM
Chaos07's Avatar
ok thanks ill get the stuff i need soon im gunna end up getting the pioneer avh42000 right now i have the avh5000 flip up screen but i jut want something different lol but tahnks for the help
Old 03-22-2010, 02:07 PM
1 task's Avatar
thinking about doing the pioneer 4200 as well....you can always add on GPS later if needed, when the price drops. ill post some pics in the next month or so when i install the unit!!
Old 03-23-2010, 11:39 PM
Copy & Paste Moderator
VIP1's Avatar
Here is my AVIC-D3 Install:
https://ls1tech.com/forums/stereo-el...installed.html
Old 03-25-2010, 08:29 PM
2000SDTA's Avatar
VIP, did you leave the plastic bottom in or did you cut that out as well? My D3 seems to be sitting higher up than yours???
Old 03-27-2010, 02:24 PM
VIP1's Avatar
The plastic shelf is still there. I only cut the standing tab in the back. If you check out the thread, you'll see pics.
Old 03-30-2010, 10:21 AM
headed-ws6's Avatar
I would say it is by far the best thing you can do to your t/a's stereo. ive had 2 single dins and a flip up touch screen in my t/a and my new double din is by far the best out of them all.
Quick Reply: Double Din in trans am ????
