clutch job buttoned up now wont start
If its not even turning over then the problem is most likely electrical. Does the radio and rest of the electrical in the car work? If so I would check the starter wires and any plugs into the transmission. Also of course check the fuses. Good luck!
Yeah i am guessing blown fuses for the starter, or starter wires ripped off, probably not the problem but is the clutch pedal touching the sensor so it will let it start, not sure if you changed out the master cylinder or not or did anything else under there. And i would definately check all other fuses to just in case.
yeah i checked all sensors for the clutch and everything is hitting fine. just to make sure we tryed to jump the clutch switch, still nothing. also i put a tester light and all fuses are fine. i get power to the posts of the starter. i also get power to the fire post when the key is turned all the way forward.
we have tripple checked all electrical connections and sensors. could my starter have gone bad just hanging there out of the way? i never had a starting issue with my car...until now.
yeah we beat on it and nothing. also tried to jump it, no dice. at work now. hope to start wrentching in a few hours. i got a starter today. if that doesnt work i am going to be super stumped.
SHE'S ALIVE!!! AND THE CLUTCH PEDAL FEELS LIKE BUDDA! new starter did the trick. now time to break the clutch in and see what i have in a few weeks!
thanks guys. everyone here is always real helpful. everything always go's smooth until your workin gon your own car. then hell breaks out. headding out of work to go rack up some miles.
