Custom Y Bend angles
Old 03-22-2010, 05:56 PM
01Blk*SS*'s Avatar
Default Custom Y Bend angles
to the custom ypipe guys:
I want to have a custom ypipe built out of oval tubing and merge into a round collector for clearance. I want to buy the piping and bring it to a shop to have them make a piece. I was wondering what angle bends are needed after the headers to the merge. thanks guys!
Old 03-22-2010, 11:18 PM
Moderator
98Aggie's Avatar
2 45
1 short straight piece
Old 03-23-2010, 01:07 PM
01Blk*SS*'s Avatar
Thanks for the reply Aggie! It seems with over 30 views, more people would chime in.
Old 03-23-2010, 01:08 PM
01Blk*SS*'s Avatar
98Aggie, how is ground clearance with that y? any clearance pics or tips to tucking the pipe up as far as possible without it hitting the floor board under throttle
Old 03-23-2010, 02:10 PM
Moderator
98Aggie's Avatar
That is the one on TXCAMSS car. The straight pipe under the drives floor has been ovalized to clear the floor. Also not in the picture on the first 90 elbow on the drives side there is a small rubber braket welded on and bolted to the floor to dampen the isolation on that side.
It takes time to fit and clearance everything but it can be done. I'm sure you've seen the one built for Patrick G Trans am that had excellent ground clearance and did not hit the floor.
Old 03-23-2010, 05:30 PM
01Blk*SS*'s Avatar
thanks for all the info, no I havent seen Patrick G's, links?
Old 03-23-2010, 10:58 PM
Moderator
98Aggie's Avatar
Old 03-24-2010, 02:06 PM
01Blk*SS*'s Avatar
awesome! thanks again Aggie
Old 03-25-2010, 10:59 AM
sjsingle1's Avatar
can you buy oval pipe or do you have to make it???
Old 03-25-2010, 12:37 PM
Moderator
98Aggie's Avatar
You can buy it - there are some companies out there. Right of the top of my head is Dr. Gas and BSR products
Old 03-25-2010, 02:25 PM
sjsingle1's Avatar
i could make my own Y..............
Old 03-30-2010, 03:20 PM
01Blk*SS*'s Avatar
can you make mine too ! haha for free of course
Old 03-30-2010, 06:48 PM
sjsingle1's Avatar
sure......I am a welder........but no welding machine
