Gears & Axles - Will a 10 bolt with moser axles hold?
nosaj
03-23-2010, 07:48 PM
Ok I have read alot about the 10 bolts breaking. I have a 10 bolt with auburn differential and 3:23s. If I change the axles to mosers and do anything else to it, will it hold up.
Intercooler2
03-23-2010, 08:03 PM
You need to read more or you would have your answer.
nosaj
03-23-2010, 08:13 PM
So I take that as a no
bigj2717
03-23-2010, 08:23 PM
:D Yep no matter how much money you throw at a 10 bolt its still the same size. Its always better to put that money towards something that will hold power.
Intercooler2
03-23-2010, 08:24 PM
That's correct. Axles aren't really what fails it is either the ring/pinion, ring bolts or the carriers. Save it for a real rear.
nosaj
03-23-2010, 08:51 PM
Alright, I will just wait until mine busts then and upgrade to a 12
sohc19974.6l86
03-23-2010, 08:59 PM
yeah im on my 3rd 10 bolt the fail because there to much flex in the housing. i have seen peolpe drop some coin and brace the housing and still fail.
96lt1m6
03-23-2010, 09:05 PM
All the mods in a 10-bolt will only be a band-aid since the main problem is the small diameter ring and pinion gear... save the coin for a 12bolt,S60 etc.
